Posted on
11-26-2019
05:27 PM
- last edited on
03-04-2025
01:53 AM
by
kh-richa_mig
The patch definition for OneDrive is no longer following the Production ring. Appreciate Jamf keeping me on stable Enterprise releases, but the built in updater on OneDrive always goes to the Production ring, so my users are constantly getting update notifications even though they are almost two more versions ahead.
Wouldn't it be better to add the production versions and let admins decide whether or not they want to hold users back on their own?
Posted on 11-26-2019 06:14 PM
Hello @beatlemike !
Thanks for bringing this to our attention.
We typically use the "Rolling out - Production Ring." Which means that the latest version should be 19.192.0926.
Apparently our automation missed this. We'll investigate that ASAP! In the meantime, is the Rolling out - Production Ring sufficient?
Jonny
Posted on 11-26-2019 06:29 PM
Thanks, @beatlemike!
Posted on 12-03-2019 11:19 AM
For sure @robinsonjo , thank you! I don't think anyone wants the insider ring on their patch management haha the build can change before production,, that would get messy quick.
Thanks for the thanks @dan-snelson !
Posted on 12-03-2019 11:26 AM
@beatlemike , no problem! We can understand that. The change was made last week and the Software Title was updated soon after this post last week. Hope this helps!
Thanks!!
Jonny
Posted on 12-03-2019 11:30 AM
@robinsonjo Yep saw it before I made it back here even, just been slow catching up. Thanks!
