a week ago
It's extremely annoying that Jamf have decided to prevent Jamf Pro cloud instances from being upgraded before 14th September to v11.9.0, after already bumping v11.8.0 of Jamf Pro.
It does not seem fair that we are still waiting for key features to be made available in Jamf Pro, which should have already been released months ago.
Why Jamf are you making life so difficult with getting new key new features made available to Jamf Pro customers?
Solved! Go to Solution.
a week ago
Looks like Jamf have now removed the restriction preventing Jamf Cloud instances of Jamf Pro from being upgraded to v11.9.0.
Have now been able to successfully upgrade Jamf Pro instances to v11.9.0 from within https://account.jamf.com
a week ago
a week ago
I don’t think is a question of fair
I see others reports that there server is not booting after upgrade the cloud to 11.9
So I think. They are on bug hunting and release 11.9.1 to public
if your account is in the organisation. You can get a feedback tenant. That run never version. Then public
a week ago
Yup, attempted to upgrade, prior to this banner message.. and now upgrading is disabled… which is new.. considering macos15 is incoming…
a week ago
11.9.1 fix a PI for JCDS. I think they skip 11.9
a week ago
It is kinda ironic as the main "selling" point is Jamf 11.9's support of the beta OS's. We are likely to see iOS 18 before the end of the month and Jamf is artificially delaying adoption of 11.9 effectively limiting our testing time.
a week ago
