Posted on 05-21-2015 02:04 AM
Hi there,
Are the jamf recon "-username" and "-passhash" options needed under Casper 9.7? I don't see them showing up in the "jamf help recon" manpage anymore.
If not, when did they go away? :-)
Thx,
Adam
Posted on 05-21-2015 02:58 PM
Not sure if/when they went away, but I have never needed to enter those flags. I just have to make sure to sudo the command
