Posted on
09-15-2019
06:47 PM
- last edited on
03-04-2025
05:32 AM
by
kh-richa_mig
Hi All,
Is there a way that the members of Smart or Static Groups can be reported to SCCM via the plugin?
For example, if i had a static group XYZ of computers - i would like to be able to know which computers are in this XYZ group?
Thanks
Posted on 09-15-2019 08:23 PM
Have you looked at webhooks? You can send a hook upon membership change and use the API to integrate. I haven't used the plugin in a very long time, and even when I did use the plugin I was just helping people set it up. I never actually used it in my environments.
Posted on 09-22-2019 08:27 AM
Hello @dmorgan_ISC
Do you know what WMI class or SQL Server table for the SCCM database you would want this information mapped to?
It is possible to map data from the Jamf Pro API to the Hardware Inventory (HINV) by modifying the XSL files included with the plug-in including custom WMI classes you create in the Configuration Manager Console. See the post Does the JSS SCCM Plugin Allow for additional WMI Classes? for more information and an example.
