Posted on 04-18-2012 09:17 AM
Hi Folks,
We have been using the Imaging suite for over a year and all has been well. Lately though, we have noticed the JAMFHelper is not opening at startup to lock the screen from user input. this means the Adobe installs and other installs running from the first run script run, but the screen is not blocked.
Are any of you having or have had similar issues? The interesting thing is if I restart the Mac a second time, the lock screen appears. The first run script runs every time, it is just the lock screen that doesn't appear after the initial restart after imaging.
Thoughts?
Posted on 04-18-2012 10:59 AM
I am finding exactly this but only with 10.7.3, when I roll back to 10.7.2 base image it runs perfectly!!
I have JSS 8.43 and only seeing the issue with 10.7.3 base OS imaging (NOT 10.7.2)
Posted on 07-30-2014 02:29 PM
it has been a few years, but have you found a resolution to your problem? I am coming across the same thing with 10.9.4
