- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 10-26-2021 11:36 AM
Hey All, I'm getting this message and also one that says JamfDaemon need updating. I've gone through all of my scripts and EAs to see which ones were calling/using Python and all have been resolved, but I'm still seeing this on new Monterey installs. Any ideas where else I can look?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-27-2021 08:47 AM
Changed the one EA that was still had python in it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-26-2021 12:39 PM
What version of JamfPro are you currently on?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-26-2021 02:12 PM
10.32.2-t1631979773
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-27-2021 06:36 AM
We are getting the same thing, but only on Monterey Test PC's.
Jamf Version - 10.32.2-t1631979773
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-27-2021 07:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-27-2021 07:44 AM
Started going through everything again this morning. Found one EA that my previous searches didn't find using python. I believe I'm good now. Rebuilt a machine a couple times this morning and no longer seeing the popups.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-27-2021 08:07 AM
Did you change anything or just retest?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-09-2021 06:07 AM
Went through all our EAs with a fine tooth comb and removed all with python code. I don't believe I have any python scripts now in our EAs but after two new enrolments (on Monterey) this morning, I am still seeing the popup "JamfDaemon" needs to be updated. Any ideas if there is a different root cause? thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-16-2021 06:03 AM
I'm seeing the exact same prompt on my new Monterey installs while running Jamf PRO 10.34.1. I went through each extended attribute and none use python.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-21-2022 12:53 PM
Here is a short-term way to supress the pop-up warning.
https://grahamrpugh.com/2021/10/25/monterey-disable-python-2-deprecation-warnings.html
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-07-2022 04:54 PM - edited 02-07-2022 04:55 PM
I'm also getting the popup about JamfDaemon needs to be updated.
If I have EAs written in both
#!/bin/sh or #!/bin/bash
Would these be a problem? They work fine.
Would python code be inside these scripts?
Or would i be able to easily see wich ones are python based on the script not starting with #!/bin/sh or #!/bin/bash ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-08-2022 04:06 AM
Its most likely there is a line in your script that is calling python that is causing the popup. You'll want to take a look at all your EAs. MacMule has steps here that can help you easily download all your scripts and EAs to look through.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-09-2022 08:02 AM
@DBrowning I took a look at that link and when I go to a users library I don't see the
~/Library/PythonWrapper/promptedapps.plist
I don't even see the PythonWrapper folder
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-09-2022 08:36 AM
You'll want to download or look at all your scripts and EAs and see if any of them call python. I believe the folder will only show items apps run from the device.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-14-2022 01:50 PM
So basically every time a RECON runs and goes through the Extension Attributes these 2 jamfdaemon or jamfmanagementservice warning will popup.
i don't see this PythoWrapper directory to get to the plist file to help pinpoint the possible cause =
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-17-2022 01:19 AM
Hi all, I face the same alert. We are using the "jamf depnotify deploy script", to install our Clients. Inside the script, there are some python calls. Is there a way to get rid of these calls and use the script anyway?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-17-2022 01:41 AM
@Anonymouscopy and paste the python calls so we can see them
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-17-2022 07:17 AM
In Line 545 to 547 -> call to detect the current user
# After the Apple Setup completed. Now safe to grab the current user.
CURRENT_USER=$(/usr/bin/python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "\n");')
echo "$(date "+%a %h %d %H:%M:%S"): Current user set to $CURRENT_USER." >> "$DEP_NOTIFY_DEBUG"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-17-2022 08:44 AM
I'd update those calls to this:
LoggedInUser=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-17-2022 12:15 PM - edited 02-17-2022 12:17 PM
Will all python calls start with this =
/usr/bin/python ?
So when I look through my uploaded scripts and EA I'll easily be able to spot python being used?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-22-2022 04:50 AM
All depends who wrote the script. Some will use the full path some will use just python. So you'd want to be looking for:
python
/usr/bin/python
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-03-2022 06:39 AM
Hi DBrowning, sorry for my late reply. I will give it a try and tell the result :)
Thanks a lot for your hint.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 02-22-2022 05:34 AM
How do I clear the JamfManagementService and JamfDaemon popups that previously appeared? So when I test it will look like the popups never appeared and popups will appear if a python script was run?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-25-2022 03:35 AM - edited 03-25-2022 03:38 AM
I've been seeing this lately and it's annoying me and I decided to do something about it, which lead me to this thread, which lead me to search through my Jamf environment. I've got several scripts and EA that use python to find the logged in user, because that was once upon a time considered Apple's best practice according to Apple's own documentation - https://developer.apple.com/library/archive/qa/qa1133/_index.html - but it's apparently no longer updated, so does anyone know where to find the best current practice for determining logged in user? I'm familiar with the more traditional shell script ways of getting the logged in username, but I was trying to be a good apple... now I find out Apple's yet again moved the goalposts.
Also need to dissect the DEPNotify config left by my predecessor since I see others here saying it's got python calls... This isn't going to be fun. My developers are already upset that built-in Python goes away in 12.3... my manager isn't going to be happy that our management tools need updating/modification because the mothership can't help themselves from pulling the rug out from under us (I know this has been forewarned for a long time, but they could have still incorporated an easy temporary bridge like when you run try to run git without it installed...
Can anyone confirm whether installing my own python makes this warning go away, or will it prompt whenever it seens any python running through Jamf?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-25-2022 04:25 AM
LOGGEDIN=$(/bin/echo "show State:/Users/ConsoleUser" | /usr/sbin/scutil | /usr/bin/awk '/Name :/&&!/loginwindow/{print $3}')
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-04-2022 05:59 PM
Thanks @DBrowning I'm more partial to
LOGGEDIN=$(/usr/bin/stat -f%Su /dev/console)
or
LOGGEDIN=$(/bin/ls -l /dev/console | cut -d" " -f4)
