Posted on 09-10-2013 06:26 PM
When trying to replicate packages from our JSS to a JDS via admin client everything seems to be working in that the progress bar keeps moving and packages are showing as being replicated. But when looking at the share on the JDS there is nothing in the share and the "replicated" packages do not show in the file system.
Both JSS and JDS are on Redhat 6.4 VM's.
Also the share on the JDS has both owner and group as "root".
Has anyone else seen this, or is there more documentation somewhere about how the JDS works?
Solved! Go to Solution.
Posted on 09-15-2013 07:31 PM
This is now solved if others have a similar issue.
The error was that the file ssl.conf did not exist.
If the file is created with the touch command:
sudo cd etc/httpd/conf.d
sudo touch ssl.conf
Then rerun the installer it all works.
Posted on 09-10-2013 07:28 PM
Further info, we have two JDS a parent and child, looking at the JAMFChangeManagement.log on the JSS during the replication process we see as below:
[dmw (ID: 2)] [UPDATE] [Package] [Wed Sep 11 11:56:38 EST 2013] ID 5 Name .................. Lync 14.0.5 20130626.pkg.zip Category Communication Priority .............. 10 Reboot Required false Fill User Template .... false Fill existing users false Uninstall allowed ..... false
[dmw (ID: 2)] [READ] [JDS] [Wed Sep 11 11:57:20 EST 2013] ID 1 IP Address ...................... Model Identifier Name ............................ utasjdssby.its.utas.edu.au Serial Number UDID ............................ 4219AEE1-4DEE-03B7-0D5F-59AA76EB3816 Location ID -1 Master .......................... false Parent Distribution Server ID -2 Distribution Point .............. true Replicate Packages/Scripts 1 Software Update Server .......... false Replicate Updates 1 Netboot Server .................. false Replicate Images 1
[dmw (ID: 2)] [READ] [JDS] [Wed Sep 11 11:57:48 EST 2013] ID 2 IP Address ...................... 10.10.146.120 Model Identifier Name ............................ utasjdsnhm.its.utas.edu.au Serial Number UDID ............................ 421920A1-26DE-2464-89A5-A300156BD979 Location ID -1 Master .......................... false Parent Distribution Server ID 1 Distribution Point .............. true Replicate Packages/Scripts 1 Software Update Server .......... false Replicate Updates 1 Netboot Server .................. false Replicate Images 1
sudo touch ssl.conf
Posted on 12-12-2013 05:03 PM
@dmw3][/url: The first command fails on our JDS. We have no such directory. Is your syntax correct? Was this run on the JDS or JSS. I'm running 10.8.5 on both with JSS and JDS v9.21.
root# sudo cd etc/httpd/conf.d /usr/bin/cd: line 4: cd: etc/httpd/conf.d: No such file or directory
Thanks
Posted on 12-16-2013 12:18 PM
Try your command with an extra / at the front. This specifies the root directory. You don't need it if you're starting from root, but your default directory isn't / , It is /Users/username. You probably want:
sudo cd /etc/httpd/conf.d
