Keychain Issues With NoMAD
  • November 20, 2017
  • 29 views
I'm having issues with Keychain, I think NoMAD is one to blame.
I have set:
<key>LocalPasswordSync</key>
And it's working fine, changing password from machine, or AD (I also have
<key>UPCAlert</key>
so I get notified). Everything gets synced, but I started getting strange messages, that I need to put my keychain Login password. If I enter new or old password, the result is same, it doesn't recognize it as a password.
So, I get popups from Apps and WiFi gets disconnected as well, asking for Keychain password.
Is there a particular plist tag which has to be included to sync Keychain, apart from
<key>UseKeychain</key>
which I use, but I don't get password synced.
Thank you.
justin_smith
  • November 20, 2017
You can specify items within the keychain to sync. I'm deploying NoMAD prefs via config file with mixed success.
KeychainItems Dictionary
https://nomad.menu/help-center/preferences-and-what-they-do/
I've had issues with SignInWindowAlert prompting and not accepting credentials, but nothing quite like what you described.
  • November 22, 2017
Justin,
I am having trouble using this feature and having it work. Could you provide one of your examples?
  • November 23, 2017
I've discussed it with Apple Engineer, this might be a High Sierra issue. Keychain is broken, actually, I know that there is something wrong with it for years now, but that's another topic. Anyways, I don't remember having this kind of issues on Sierra
