limitSSHScope.sh script - Is it possible to modify script to limit SSH access to one group?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 05-24-2011 08:05 AM
In the Casper 8.1 resource kit, I noticed that there was a script in Resource Kit - February 2011/All Tools/Security Scripts called "limitSSHScope.sh". This particular script is scoped to allow one user through. Has anyone modified the script so that it's allowing one group through, instead of one user?
If you have, or have another similar script that you're using, would you please share what you did?
Thanks,
Rich
Rich Trouton
troutonr at janelia.hhmi.org
JFRC Help Desk
phone: x4030
email: helpdesk at janelia.hhmi.org
The best way to get in touch with me is through email.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-24-2011 08:13 AM
You can nest a group.
That script looks like it creates the group, even if it doesn't exist.
You can use dseditgroup to add an existing group to the local com.apple.access_ssh SACL group.
Add the local admin group to it: /usr/sbin/dseditgroup -o edit -a admin -t group -n /Local/Default com.apple.access_ssh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 05-24-2011 10:29 AM
Thanks, Nate. I was thinking about using dseditgroup for this, so I'll make some edits to the script to use that command like you've laid out below, instead of the dscl commands included with the script.
Rich
