Hi Peps
I am now testing multiple distribution points, up to now I have only had 1 JSS server but i am testing out 2 brand new xserves to test a possible new setup.
I have setup server 1 as a JSS and Distribution point I have setup server 2 as a Distribution point
Then I set server 1 as the master with server 2 as its failover and ticked the enable automatic load balancing.
In the JSS i can connect to both servers and in Casper admin both show up in the servers side bar.
They sync using rsync fine.
I can also image macs from both servers by setting the server in the autorun details. Howver how do I get the load balancing working for the autorun, I have ticked the load balancing option in the Management Preferences section of the JSS.
But in the autorun details i have to select server 1 or server 2.
If i use Casper Remote is load balances the servers fine.
what am i missing?
regards
Criss
Criss Myers
Senior Customer Support Analyst (Mac Services)
Apple Certified Technical Coordinator v10.5
LIS Business Support Team
Library 301
University of Central Lancashire
Preston PR1 2HE
Ex 5054
01772 895054
