Hi
Has anyone already implemented a load balancer for Jamf Pro with nginx and is willing to share the configuration?
Or which proxy do you use?
Scenarion: 2 Tomcat server in cluster mode with Jamf Pro behind a load balancer which is terminating SSL.
@anverhousseini did you find anything about this? I'm looking at this as well.
@prbsparx I'm running several nginx proxies successfully. Do you need any help?
I'm also interesting in setting up nginx proxies. Can you share your experience and config ?
I also would be interested in your configuration documentation if you were willing to share.
This is our config, we are managing the SSL cert with Let's Encrypt:
upstream jamf_backend {
  zone tomcat 64k;
  ip_hash;
  server 192.168.1.10:8080 max_fails=3 fail_timeout=30s;
  server 192.168.1.11:8080 max_fails=3 fail_timeout=30s;
server {
  if ($host = jamf.example.com) {
    return 301 https://$host$request_uri;
  listen 80;
  server_name jamf.example.com;
  location / {
    return 301 https://$server_name$request_uri;
server {
  listen 443 ssl http2 default_server;
  ssl_certificate /path/to/cert.pem
  ssl_certificate_key /path/to/key.pem
  include /etc/letsencrypt/options-ssl-nginx.conf;
  ssl_dhparam /etc/nginx/ssl/dhparam.pem;
  client_max_body_size 1024M;
  send_timeout 300;
  location / {
    include /etc/nginx/proxy_params;
    proxy_connect_timeout 300;
    proxy_send_timeout 300;
    proxy_read_timeout 90m;
    send_timeout 300;
    proxy_pass http://jamf_backend/;
    proxy_redirect off;
    error_page 500 502 503 504 /custom_50x.html;
    location = /custom_50x.html {
      root /usr/share/nginx/html;
      internal;
@anverhousseini I'm running into an issue with flushing logs specifically where I get 504 Timeouts from the NGINX load balancer.
You mentioned these settings:
proxy_connect_timeout 300; proxy_send_timeout 300; proxy_read_timeout 90m; send_timeout 300;
How did you determine what value to set for each? Was there anything that helped you gauge it better?
