Posted on 01-15-2014 12:52 PM
We recently reimaged a macbook and now can't log on to the PC. FileVault is enabled. When I boot with Command+R to do a recovery and try to unlock the hard drive with the FileVaultMaster.keychain, I get a message "Error 69749 Unable to unlock..." .
Anybody seen this error before?
Posted on 01-15-2014 01:10 PM
I am wondering if it is because you do not have the user accounts on the machine that have encryption. Can you drop an image with a user that originally had access on it?
Posted on 01-16-2014 01:58 AM
We have had user forget the FileVault keys..
See what you can do..
But if all else fails, then you can:
Boot from another disk, and use disk utility to reformat the HD -- loosing all it's contents in the process..
-- But you will end up with a disk that you can do a fresh install on..
-- So that's a "last resort" solution..
Posted on 01-16-2014 04:03 AM
Thanks for the responses, however my problem is that the encrypted drive is locked. I booted from a thumb drive with the OSX image, but when I try to run disk utility to reformat the drive, the partition is locked and I don't have a password to unlock it.
Posted on 01-16-2014 04:20 AM
Sorry, I needed to be clearer: In the case where you decide to erase the HD.
You will need to re-partition the HD - since the OLD partition is locked.
But it can be blown away, and replaced by a new partition.
( This process still preserves security - since the old data cannot be accessed )
( But you do end up with a machine that is useable one again.. )
So Boot from an external, Repartition the internal, Reformat the internal, then Re-install...
Partition Map Scheme should be: GUID ( = OS X Standard )
( The old apple one was for pre-OS X days )
-- Regards
-- Peter
Posted on 01-16-2014 08:24 AM
I did a little more research and found the instructions to fix my problem. I had to use the Disk Utility cli command to delete the logical volume group, then I could reimage the drive. http://derflounder.wordpress.com/page/2/?s=filevault
Posted on 01-16-2014 08:29 AM
All you need to do is exactly what @PeterClarke mentioned, repartition the drive to a single partition. We do this literally everyday on FileVault 2 encrypted systems without first unlocking the drive. We have a single line command as part of our DeployStudio workflow that flattens the drive before starting the imaging. Never fails to work as far as I've seen.
