Has anyone experienced issues with imaging a 10.11.4 dmg to a newer MacBook Air in which it will freeze about 50-75% on the kernal screen after imaging?
It doesn't seem to happen on models other than the MacBook Air. I can successfully deploy this image on MacBook Pros and iMacs.
If I use a 10.11.3 dmg, it seems to work fine. My workaround is adding the 10.11.4 combo update in the configuration but I'd like to save a bit more time by having the update baked in.
MacBook Air (13-inch Early 2015) + 10.11.4 ASR Issues
