macOS Monterey Smart Group
sirsir
Contributor
What is the proper way to make a macOS Monterey Smart Group? Typically I put in the macOS number as the criteria (10., 11., etc) but that doesn't seem to work... It's catching OS X Sierra 10.12.x machines in it.
1 ACCEPTED SOLUTION
awoodbury
Contributor
Contributor
Here is a screenshot with the Criteria for our Smart Group.
8 REPLIES 8
awoodbury
Contributor
Contributor
That was stupid simple, thanks!
scottb
Honored Contributor
You can make it even simpler:
True, this will also work, but I preferred it to be future proof for this fall. ;-)
I'm using "Operating System", "matches regex", "^11" - which means it has to start with "11"
BenApple
New Contributor II
klax-online
New Contributor
Apparently, it's not working for Ventura smart groups yet - at least not with the beta installed?
I've got a test machine, with 13.0 beta 8, and none of the above descibed methods work... So it never turns up, no matter whether I use @awoodbury's solution (greater than or equal 13.0), or the regex one, etc. First I thought: maybe Jamf Pro interprets the beta versions as lower than the regular 13.0, but it should at least be shown when using "greater than 12.6"; doesn't seem to be the case though. Any ideas?
klax-online
New Contributor
EDIT: it could in fact be an issue with the relevant machine; it was deleted from Jamf some time ago, and just today added back (test mac)... I'll check first, if it turns up tomorrow and if not, reimage it + check again.
