Make client MacOS devices restart after running for x days
  • October 29, 2019
  • 0 replies
  • 6 views
!/bin/sh
Set UPTIME output for echo
UPTIME=uptime | cut -d ',' -f 1
clip the number of days of uptime and set as variable Days
Days=echo $UPTIME | cut -d ' ' -f 3
Check that second step is cutting correct field
echo $Days
Set the max number of days of uptime to Parameter 4
RUNNING=$4
if [ $Days -gt $RUNNING ]
then
shutdown -r now
