Posted on 01-19-2021 01:03 PM
Greetings all!
I'm wondering something. We currently want to have homepages set once during setup. I was imagining using something such as
/usr/bin/defaults write /Users/$currentUser/Library/Preferences/com.apple.Safari HomePage -string "https://apple.com"
However, it seems this is denied in Big sur, correct? Is there a way i can accomplish this without a config profile? We want to allow users to change but initially use this homepage.
Posted on 01-19-2021 01:37 PM
@jclark27 It's not the simplest process in the world, but the approach I adopted for deploying Configuration Profiles with settings I want to allow users to change:
1) Create a Self Service policy the user can run which executes a script to create a hidden file used as a flag the user is requesting the profile be removed. The policy also runs a recon.
2) Create an Extension Attribute which looks to see if the flag file from Step 1 exists
3) Create a Smart Group whose membership is any computer where the EA from Step 2 reports the flag file exists
4) Use the Smart Group from Step 3 as an Exclusion for the Scope of the Configuration Profile I want the user to be able to remove
Posted on 01-20-2021 07:10 AM
Thanks so much for the input!
Wow ok so I’m guessing I’m not too crazy for thinking this seemed harder than it used to be haha.
Cheers
