MATLAB and PPPC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
10-25-2019
08:46 AM
- last edited on
03-04-2025
07:00 AM
by
kh-richa_mig
Has anyone successfully whitelisted MATLAB with the PPPC utility or another method? It doesnt allow me to add the app, it just ignores it. Ive tried PPPC Utility 1.1.2 with MATLAB 2017a through 2019b.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-25-2019 08:51 AM
Hey @alexkaloostian, thanks for the post. That typically means that the app doesn't have a code signature, which is required for things to be whitelisted. You can confirm this by running the following command and see what it returns:
codesign -dr - /Applications/Application.app
If it isnt signed it should return something like "code object is not signed at all"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-14-2021 03:28 PM
Anyone ever figure out a fix for this? I'm trying to pre-approve Matlab 2020b for ~/Documents access and I can't because it isn't signed.
"Failed to get designated code requirement. The executable may not be signed. Error: The operation couldn't be completed. (OSStatus error -67062.)"
Can confirm codesign returns a "code object is not signed at all".
This makes me confused why MATLAB even launches without any issue if it's not signed. You can add Matlab to Privacy manually, but I don't think there's any way to create a PPPC profile for it if it's not signed, is there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-15-2021 06:41 PM
Does matlab run ok otherwise? I have the same version deployed but never tried setting any access for it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 06-16-2021 09:12 AM
it does work fine otherwise. when you launch it, it prompts for access to Documents. which is fine for employees, but when it's a lab, it would be nice to pre-approve.
There's a path option for PPPC profiles, but I'm unclear how that actually works (and not even sure if it does if it's not signed).
