Posted on 12-06-2021 01:48 PM
Hi
We are running into an issue with installing bitdefender endpoint on MacBooks with Monterey.
For Big Sur we followed the following configuration: https://www.bitdefender.com/business/support/en/77209-87686-install-security-agents---use-cases.html...
However we noticed that this doesn't necessarily work on Monterey. In Big Sur the dmg would install the pkg in the /Users/Shared folder (see composer screenshot). When running this on Monterey we get the error: Result of command:
installer: Error - the package path specified was invalid: '/Users/Shared/antivirus_for_mac.pkg'.
My question is: is there a difference between Monterey and Big Sur directories where dmgs get installed into? Or does it look like I am missing something here?
Posted on 12-06-2021 02:12 PM
I noticed that the S in /Users/Shared was not capitalized in composer, I believe that might be the issue
Posted on 12-07-2021 07:43 AM
Just fixed that and am still getting the same errors unfortunately
