Posted on 08-03-2020 03:24 PM
Hi there my iphone xr is stuck in recovery mode after udate of ios 13.6.I hav reset my iphone to give it to my brother but it stucked in recovery mode i hav tried every thing but cant fix it done restore with i tunes but no result plzzz tell me how to fix it i am very stressed
Posted on 11-12-2020 12:43 PM
Hi Abdul_123_hadi
Glad to offer my help!
You can try these:
Generally, we use iTunes to Fix iPhone Stuck in Recovery Mode.
Step 1. Open iTunes and connect your iPhone to your computer.
Step 2. A window saying "iTunes has detected a device in Recovery Mode" may show up. Just click on the OK button once you've seen it.
Step 3. Click on the Device icon and then tap the Summary tab. After that, you need to press the Restore iPhone and click the Restore button to reset your iPhone to factory settings.
You can also use some iOS system recovery software. It can help users repair different iOS problems. It is capable of retaining all the existing data.
Here is a passage talking about it:
iPad 2 stuck in recovery mode
Posted on 11-12-2020 09:17 PM
If you’re on a Mac, you can download Apple’s Configurator 2 App for the App Store and attempt to do recovery from it as well.
a week ago
Try the following:
If none of the above methods work, consider a hardware problem.
Here is a video that may help:https://www.youtube.com/watch?v=OScIw4eqlTI&t=135s
