Need some help patching AndroidStudio
Dkurtz
New Contributor II
I am attempting to install AndroidStudio 2023.2.1 on systems that are currently running 2023.1.  I am using the patch management system to deploy these updates.  I have taken the dmg file from Google and converted it to a pkg file with composer.  However when I push it through patch polices I get an error stating that the program is trying to install to the system volume.  See error below.  Any help would be appreciated.
installer: Package name is AndroidStudio - Iguana | 2023.2.1 Patch 1 installer: Upgrading at base path / installer: The upgrade failed. (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance. The package is attempting to install content to the system volume.)
3 REPLIES 3
mojo21221
Contributor II
I had a hard time updating AndroidStudio in the past as well... Switched to using https://github.com/Installomator/Installomator and that took care of my issue.
Dkurtz
New Contributor II
Great thanks, I will check it out.
Dkurtz
New Contributor II
Here is a good write up on Installomator for Jamf.
Using Installomator with Jamf Pro – Scripting OS X
