Need to disable VoiceOver shortcut and TextToSpeech
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
03-13-2017
02:29 PM
- last edited
Tuesday
by
kh-richa_mig
We have 900 MacBook Airs, running 10.11.6, in a 1:1 environment. We are preparing to do state testing on them after spring break. During trials, we found out that students used VoiceOver and Text-to-Speech to read the test questions to them. Unless they have an accommodation for that, we need to prohibit that behavior.
I've written a script that disables the things that need to get disabled, but a reboot is required in order to make them stick:
USER=$(w | grep console | awk '{print $1}')
#Set TextToSpeech hotkey to something else
/usr/libexec/PlistBuddy /Users/$USER/Library/Preferences/com.apple.speech.synthesis.general.prefs.plist -c "set :SpokenUIUseSpeakingHotKeyCombo 2055"
#Turn off TextToSpeech
/usr/libexec/PlistBuddy /Users/$USER/Library/Preferences/com.apple.speech.synthesis.general.prefs.plist -c "set :SpokenUIUseSpeakingHotKeyFlag false"
#Disable Cmd-F5 hotkey for voiceover
/usr/libexec/PlistBuddy /Users/$USER/Library/Preferences/com.apple.symbolichotkeys.plist -c "set:AppleSymbolicHotKeys:59:enabled false"
The complicating factor is that we're running Deep Freeze, and these settings are in the frozen system partition. So, if we reboot, the settings revert, and the script is useless.
How do I use launchctl to reboot the services to make these take effect immediately?
I think
killall -SIGHUP com.apple.speech.speechsynthesisd
will take care of the speech setting, but how do I reboot the keyboard shortcuts (cmd-F5), so VoiceOver is suspended?
I am using Configuration Profiles to make sure the relevant Preference Panes are gray out.
Thanks in advance!
- Labels:
Scripts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-14-2017 04:59 AM
Have you tried
killall SystemUIServer
This should have the desired effect
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-14-2017 06:53 AM
Thanks for the idea, but it had no effect.
