Net running slow after setting the homepage through config profile
  • July 6, 2023
  • 10 views
Asifahmed
Hello All,
Need an explanation, I did set home page and startup page by  config profile, I noticed that after mac boot up it takes time to connect internet, any resolution to make it perfect ?
1 reply
sdagley
  • July 6, 2023
@Asifahmed There should be no connection between setting the home and startup page preferences via a Configuration Profile and slow Internet connectivity unless you made other changes too. Try removing the Configuration Profile and see if that changes the behavior. If it does look closely at what you actually set in that profile to see what triggered the problem.
