Netboot permissions issue?
  • August 17, 2010
  • 0 views
My current .nbi image works great! But I have ran into a problem. We were moving the Xserve to a different VLAN in our location (hcusgr153) and after hitting "N" on a Mac laptop the netboot started fine, but when I go to image the machine from the same Xserve box (hcusgr153) it says "The Distribution Point could not be mounted. Please verify your network connection or try another Distribution point" When I try the NY distribution point (hcusny153) it works fine. Could this be a permissions issue?
Thanks
Neal C. Smith IV
1 reply
  • August 17, 2010
Now you are imaging out of Casper Imaging or are you using the netboot imaging process (NetInstall or NetRestore)?. If you are using casper imaging you need to check your shares to make sure casper admin and casper install users and passwords match up with what you have entered in under the distribution points in JSS.
-- Grant Lutz
