3 weeks ago
Hello,
I am getting this message when I attempt to uninstall or install Netskope from Jamf, which prompts me to elevate.
I have given both the Netskope and the Remove Netskope Client full disk access.
I am using the uninstall script for Jamf, provided by Netskope on their download page.
I don't know what more I can do to prevent the pop-up. Help?
Solved! Go to Solution.
3 weeks ago
As @jamf-42 mentioned, if you deploy a System Extension and don't set it to the Removable System Extensions under the System Extension Types dropdown, then when a script later tries to remove it, you'll get prompted to enter an admin username and password. That's just how it works.
3 weeks ago
probably that the config profile for the system extension is not set to be removable..
3 weeks ago
Where is that setting?
3 weeks ago
ignore me.. was thinking something else.. paste the script here.. lets see what it does..
3 weeks ago
3 weeks ago - last edited 3 weeks ago
on the config profile for the system extension, how is this set?
On a TEST device, set this to Removable and try try the script again..
Do not scope to production..
3 weeks ago
3 weeks ago
