NetSUS advice
May
Contributor III
Hi
i've installed NetSUS V4.1 on an Ubuntu VM in Azure and testing the catalog url in the browser
http://serveripaddress/content/catalogs/others/index-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1_Production.sucatalog
and i get
The requested URL /index-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1_Production.sucatalog was not found on this server.
i can get to the catalogs directory in a browser but it shows nothing, 90895c49cd7b447c9476cdf979e96bd7
if i ssh onto the server i can see all the sucatalog files in /data/netsus/content/catalogs/others/
There are a couple of steps that i may have done incorrectly when setting it up ?
- I manually configured the server using repoutil --configure and set an attached disk as the install location (as the boot disk doesn't have enough space)
- I added 2 branches and set one as root, when i tried the Sync Manually button nothing appeared to happen (looking at the volume) so i ran the repo_sync command to sync, i can see all of the downloads and catalogs now so it looks like it worked but the web interface shows last sync as never
Any pointers gratefully received !
3 REPLIES 3
sdagley
Esteemed Contributor III
@May Did you turn on the checkbox "Ensure that computers install software updates from the NetBoot/SUS/LDAP Proxy server instead of downloading and installing them from Apple's software update server" on the Software Update Server settings page? That's a common culprit with the NetSUS not serving updates.
May
Contributor III
@sdagley Thanks, yes that's on.
I'm not sure if it's because i ran the sync using the repo_sync command as using the Netsus GUI Sync button seems to do nothing and shows Last Sync as never, the odd thing is that i can reach the Catalogs directory in a browser but not the catalog urls.
77d20da09736413a966fe3a359ed0243
May
Contributor III
It looks like it is syncing ok as the modified time is at 3PM when i have the sync set,
i just can't figure why the urls are inaccessible in a browser
Catalog URLS in /data/netsus/content/catalogs/others
drwxr-xr-x 3 root root    4096 Sep 20 15:00 .
drwxr-xr-x 4 root root    4096 Sep 15 15:00 ..
drwxr-xr-x 2 root root   20480 Sep 20 15:00 archive
-rw-r--r-- 1 root root   25959 Sep 20 15:00 index-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1_Production.sucatalog
-rw-r--r-- 1 root root 3639733 Sep 20 15:00 index-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
-rw-r--r-- 1 root root 5685653 Sep 20 11:55 index-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog.apple
-rw-r--r-- 1 root root   28146 Sep 20 15:00 index-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1_UAT.sucatalog
-rw-r--r-- 1 root root   37223 Sep 20 15:00 index-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1_Production.sucatalog
-rw-r--r-- 1 root root 3573459 Sep 20 15:00 index-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
-rw-r--r-- 1 root root 5576810 Sep 20 11:55 index-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog.apple
-rw-r--r-- 1 root root   42557 Sep 20 15:00 index-10.11-10.10-10.9-mountainlion-lion-snowleopard-leopard.merged-1_UAT.sucatalog
-rw-r--r-- 1 root root   13786 Sep 20 15:00 index-10.9-mountainlion-lion-snowleopard-leopard.merged-1_Production.sucatalog
-rw-r--r-- 1 root root 1223662 Sep 20 15:00 index-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
-rw-r--r-- 1 root root 1769310 Sep 20 11:55 index-10.9-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog.apple
-rw-r--r-- 1 root root   21859 Sep 20 15:00 index-10.9-mountainlion-lion-snowleopard-leopard.merged-1_UAT.sucatalog
-rw-r--r-- 1 root root     492 Sep 20 15:00 index-leopard.merged-1_Production.sucatalog
-rw-r--r-- 1 root root  809327 Sep 20 15:00 index-leopard.merged-1.sucatalog
-rw-r--r-- 1 root root 1030286 Jul 13 12:48 index-leopard.merged-1.sucatalog.apple
-rw-r--r-- 1 root root   12264 Sep 20 15:00 index-leopard.merged-1_UAT.sucatalog
-rw-r--r-- 1 root root     504 Sep 20 15:00 index-leopard-snowleopard.merged-1_Production.sucatalog
-rw-r--r-- 1 root root 1453059 Sep 20 15:00 index-leopard-snowleopard.merged-1.sucatalog
-rw-r--r-- 1 root root 1982166 Jul 13 12:48 index-leopard-snowleopard.merged-1.sucatalog.apple
-rw-r--r-- 1 root root   12276 Sep 20 15:00 index-leopard-snowleopard.merged-1_UAT.sucatalog
-rw-r--r-- 1 root root     509 Sep 20 15:00 index-lion-snowleopard-leopard.merged-1_Production.sucatalog
-rw-r--r-- 1 root root 1946424 Sep 20 15:00 index-lion-snowleopard-leopard.merged-1.sucatalog
-rw-r--r-- 1 root root 2639054 Sep 20 11:55 index-lion-snowleopard-leopard.merged-1.sucatalog.apple
-rw-r--r-- 1 root root   12281 Sep 20 15:00 index-lion-snowleopard-leopard.merged-1_UAT.sucatalog
-rw-r--r-- 1 root root    3291 Sep 20 15:00 index-mountainlion-lion-snowleopard-leopard.merged-1_Production.sucatalog
-rw-r--r-- 1 root root 1507719 Sep 20 15:00 index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog
-rw-r--r-- 1 root root 2084954 Sep 20 11:55 index-mountainlion-lion-snowleopard-leopard.merged-1.sucatalog.apple
-rw-r--r-- 1 root root   21328 Sep 20 15:00 index-mountainlion-lion-snowleopard-leopard.merged-1_UAT.sucatalog
