Posted on β10-17-2013 08:35 AM
I have created network segments for my Distribution Points and my Software Update Servers. If I want my users to switch to Apple servers for Software Updates outside my network can I do the following. Can I create a network segment of 1.0.0.1-255.255.255.254 and specify the Default Software Update Server as "No Software Update Server"? Will this switch the Update Server to Apple offsite and then use the Default Update servers that I have setup for my onsite network segments?
Posted on β10-18-2013 01:18 PM
Wouldn't that external range include all of your internal ranges?
Posted on β10-18-2013 01:33 PM
@bog, No, thats not the way Network Segments work. You can define an "Internet" segment that encompasses all your internal smaller segments, but those smaller ones will still apply to any Macs that fall into them properly. That's essentially how we have things set up. As many Network Segments as we were able to identify were created in the JSS, and then we have a global "internet" one for any Macs that don't fall into any of those more specific ones.
@dyossi, as for how to get your Macs to point to Apple's SUS., I actually thought there was a built in "apple.com" one as part of the JSS, but looking again I only see "No Software Update server". I'm not sure if that actually reverts them back to apple.com or not though. I guess you can give it a try and see.
Edit: Ah, I know where the 'apple.com' address shows up now. In a policy within the Override default policy settings > Software Update Server list, but that may not actually help you in this case.
Posted on β10-19-2013 11:45 PM
