Notes vs Info Fields in Casper Admin
  • May 5, 2015
  • 4 views
This may be a simple question, but I couldn't find it in the admin guide, Google, or elsewhere in JAMFNation:
What is the difference between the Notes and Info fields for items in Casper Admin (or the JSS)?
  • May 5, 2015
Info is visible in Casper Remote and Imaging, so Info is intended for the techs using the packages.
Notes are only visible if you have access to the packages (Casper Admin/web interface), so Notes are for the group creating the packages.
  • May 5, 2015
Thank you! I thought it was something like that, but I wasn't sure where it displayed.
