Posted on 03-19-2024 07:12 AM
We have an on premise Jamf distribution point. It appears to have MySQL and Java installed. I don't believe these components are necessary for a distribution point but have been struggling to find a definitive answer. Does anyone know if I can just uninstall these without affecting the DP
Many thanks
Posted on 03-19-2024 07:21 AM
The distribution point should not have anything installed on it. It really just needs to be a file share with 4 directories, Casper Data, CompliedConfigurations, Packages, and Scripts. Maybe at one point in time your Jamf database was hosted on that server as well.
Posted on 03-19-2024 07:22 AM
DP is just SMB / HTTP share.. No need for MySQL or Java..
Posted on 03-19-2024 11:39 AM
Unless your server that has Jamf installed, is also used for the DP as well.
