Posted on 09-27-2011 10:06 AM
I have the same OS on the composing computer as the clients. (10.6.8).
Some of the packages composed give me an error after installation of the
app. It saysŠ."check with the developer to see if this version is
compatible with the version of OS X."
Any thoughts?
Thanks,
Kevin Hill
Albany ISD
Tech Director / Assistant Principal
Lion Pride
Posted on 09-27-2011 10:27 AM
I had this error on a pkg I created in packagemaker...
Never got to the bottom of it.
Regards,
Ben.
Posted on 09-27-2011 10:49 AM
That's kind of a generic error from the Apple Installer when it couldn't
On 9/27/11 12:06 PM, "Kevin Hill" <khill at albany.esc14.net> wrote:
install something. Could mean many things. Adobe applications when
packaged with AAMEE, for example, don't like to install sometimes when
other Adobe applications are running.
Try installing your package while at the login window or as a policy when
a user logs in and see what happens.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
Posted on 09-27-2011 11:22 AM
Could be in your process of making the packages. Are they packages from vendors? Any errors in the jamf log? Did they work previously or are they all new ones? What are the apps?
Brendon Cunningham
Senior Technical Analyst
Desktop Engineering
508-390-5620
brendon_cunningham at tjx.com
Posted on 09-27-2011 07:19 PM
Does the package leave a receipt? Check the installer log to see how far it gets.
Cheers, - D
Sent from my Tricorder. ?
