Package install help
  • January 27, 2021
  • 15 views
Hi All ,
Installing Cortex which works fine however how to get around to stop the need for logged in user to allow via security and privacy.
I have tried to find documents on how to fix this but I am going around in circles.
I have created a local admin account via jamf which gets added to the machine I was hoping I could use this account or even the jamf management account get the package to somehow just continue without the need for any manual input on Macbook.
PaulHazelden
  • January 28, 2021
You want to look and see if PPPC can provide the right settings for you. Create a PPPC policy for the App and add in the settings you want. There is also an App version of it available. Some settings are not available to set in this way though. Its not an App I have used, so I don't know which of the settings you are looking for.
PaulHazelden
  • January 28, 2021
https://github.com/jamf/PPPC-Utility
