Package Storage Location JDS Instances
KadenA
New Contributor
Is it possible to change the Package Storage Location on JDS Instances?
Thanks André
3 REPLIES 3
ammonsc
Contributor II
I would like to know the same thing.
stevewood
Honored Contributor II
Mac or Linux? I'm not certain about the Mac side, only because I haven't set one up, but as far as Linux goes, you might want to check this discussion:
https://jamfnation.jamfsoftware.com/discussion.html?id=8162
The only way I was able to move the location was to symlink it to the new location.
wilesd
New Contributor III
Feature request - https://jamfnation.jamfsoftware.com/featureRequest.html?id=1687
