Papersheet not availaible for printer
ErgodirektMac
New Contributor III
Hello,
i created a new printer in JSS.
The printer has tow papersheets but if the printer is installed no papersheet is availaible in the options of the printer.
What is wrong with my configuration ?
Kind regards and thx for your help.
Frank
fc80e33f2fab472daff3a1f0b2c68173
fad1d8eb5b75495f80f937cab43fc592
4480599ccef942f08e45e3e138e1c718
596f445551f14d75bdf2b00b76ed48f7
e208a82a0a204e798efd4eaedfb43188
1 ACCEPTED SOLUTION
ErgodirektMac
New Contributor III
Problem is solved.
With the installation of the driver, the papersheet is availaible in the overviewfa9311f3fadf4905a49ff2aa0ae97974
2 REPLIES 2
ErgodirektMac
New Contributor III
No ideas ?
My scripting is very bad so i need help please.
Kind regards,
Frank
ErgodirektMac
New Contributor III
Problem is solved.
