Parental Controls Settings
darkLord
New Contributor
It has come to our attention that our students are constantly imessaging in class rather then do their daily assignments. I have searched around and found that imessage can only be disabled under the Parental Controls settings.
What I am wondering now is if there is a way to push all the setting in the parental controls out to all student devices without having to configure it onto every device user account.
I know this might not be possible, but it is worth a try to see if it is possible.
1 REPLY 1
Chris_Hafner
Valued Contributor II
Yes... I know this is an old post, but if you're looking for an answer still, you just need to scope the policy to all of the student computers. This depends on how you've organized the computers in the JAMF Pro. Do you have them all named something specific? Do you use "Departments" to designate user devices?
