Posted on
12-29-2016
10:50 AM
- last edited
2 weeks ago
by
kh-richa_mig
We currently have screen sharing/remote management available on our test Macs. We are getting ready to roll out Macs but all of our field engineers use Windows 7 laptops for their work. At this time they do not have access to a Mac for their daily work.
I have not been able to find a software that will allow PC to Mac remote management in our environment. We use UltraVNC in the field but I have not been able to get that to also allow PC to Mac management. When I use the IP address to remote in I receive an error message stating, "No supported authentication methods."
For those of you that have a majority Windows environment, what software are you using on your PC to remote into a Mac? Any suggestions are greatly appreciated.
Posted on 12-29-2016 11:06 AM
We ran into the same problems because of mobile devices. Any device hardwired was easy as it's IP never changed and VNC works for them. Best fix was to setup ESXi server and make VM's for each tech. Let them customize it and break it, learn it, etc. Then they can use Screen Sharing or Casper Remote from within the VM. This also allowed them to use their VM from anywhere, not just their desktops. We did need set some settings.
Our first boot script handles this for us.
1. Make sure VNC password is enabled
2. ARD users and privileges are set.
#Set VNC console default here
defaults write /Library/Preferences/com.apple.RemoteManagement VNCAlwaysStartOnConsole -bool true
# Reset VNC Password
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -configure -clientopts -setvncpw -vncpw PASSWORD -restart -agent
# Reset Screen Sharing password and privs
# Set ARD privs and users with these two lines. They MUST be separate lines!
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -activate -configure -allowAccessFor -specifiedUsers
/System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -configure -users USERS -access -on -privs -all -restart -agent
Posted on 12-30-2016 02:18 AM
There are many cross-platform remote assistance tools available. You may already have access to one.
Most chat clients and remote meeting software has some sort of screen sharing capability.
Bomgar - https://www.bomgar.com
WebEx Support Center - https://www.webex.com/products/remote-support.html
Cisco Jabber - http://www.cisco.com/c/en/us/products/unified-communications/jabber-mac/index.html
Citrix Go To Assist - https://get.gotoassist.com
Lync Desktop Sharing (Skype for Business for Mac does not fully support this yet) - https://support.office.com/en-us/article/Share-your-desktop-Lync-for-Mac-1FD36E20-424F-41E5-8669-B45...
Posted on 12-30-2016 05:46 AM
Thank you @millersc and @ericbenfer . I'm going to look into these suggestions.
Posted on 12-30-2016 02:31 PM
There is also Remotix which allows Windows users to connect using Apple's native Screen Sharing protocol. See https://nulana.com/remotix-windows/. I have not personally used the Windows version so I can't speak to how well it works, but I have used the iOS version at home and it has worked really well to connect to my iMac.
Posted on 12-30-2016 05:40 PM
you could also use teamviewer
Posted on 12-31-2016 05:28 PM
Different VNC clients will work with macOS' VNC server, assuming the Mac side is enabled (note that a password must be set on the Mac VNC server to accept an incoming connection), it's a matter of figuring out which settings work on the Windows VNC client side to successfully connect - this varies by Windows clients and not all Windows VNC clients can successfully connect to the native Apple VNC server. Unfortunately no Windows VNC clients natively support the Mac VNC functionality of ARD that tunnels authentication through SSH and supports drag and drop file transfers.
There are a few different paths to take here:
Posted on 01-03-2017 05:01 AM
TeamViewer.
Posted on 01-06-2017 05:07 AM
Thanks everyone. I am looking into these solutions.
Posted on 11-03-2017 12:08 AM
You can use on premise R-HUB remote support servers http://www.rhubcom.com/v5/remote-Support.html for remotely accessing MAC computers from PC. It provides simple and easy to use interface and works from behind the firewall, hence better security.
