Has anyone seen/ know about any problems installing packages at the login screen for lion?
On Snow Leopard I'v been installing a package at the login screen after imaging, which streamlines the imaging process since it doesn't require anyone to be logged in at the time.
Its a PKG that is copied to the HD, and then launched via script. Its done this way because an install config file in the same local folder is referenced during the install.
Now, with the Lion client I'm working on, this same package fails when launched at the login screen. If a user is logged in, it works fine.
