Portable home directory not honoring exclusions
rgerman
Contributor
Hello,
I am runing 10.6 server and am introducing 10.8 clients. I am using Active Directory with an extended schema. I have several sub-folders in the users Documents folder set as homesync exclusions. Two folders are Microsoft User Data and Parallels. These folder do not sync properly and are huge... so I exclude them. I have noticed OS 10.8 does not appear to be honoring exclusions for homesync. Has anyone else experienced this issue and/or found a solution.
Thanks in advanced,
Ray
1 REPLY 1
rgerman
Contributor
I found out what the problem is....
When logging in, the system was recieving the /Library/Managed Preferences/ "username" file from the server which includes all of the exclusions for HomeSync. When the user launched Parallels Desktop 8, the users Managed Preferences disappeared.
I was able to reproduce the issue... so it looks like Parallels Desktop 8 is misbehaving... I have a ticket open with them. I'll post what they find.
Thanks, Ray
