Pre-stage enrollment happening more than once
  • June 17, 2021
  • 10 views
The pre-stage seems to happen twice.
New Mac, gets picked up for remote manage goes through the pre-stage connecting to AD(setup accounts) and then into depnotify to install apps. That all goes fine with no problems, it finishes up getting to desktop and then I do a restart.
It then restarts back into the pre-stage and I have to do it all over again, with account creation and app installs. Can anyone point me in the direction of why this might be happening?
1 reply
EmreU
  • August 10, 2021
How many pre-stage configuration do you have on your jamf environment?
If a device assigned to the multiple pre-stage enrollment it can happen.
