Problem importing plist manifest to JSS
Cem
Valued Contributor
I have raised this with Jamf already but anyone had a problem importing plist manifest files in to JSS?
Yes I have ran plutil ...and Jamf guys managed to import my plist to their JSS without any problem.
I have tried different browsers and Macs. Even tried from server root level locally.
Error I am getting is; format not recognised or similar (not at work now so don't remember exactly)
Cem
Sent from my iPhone
7 REPLIES 7
talkingmoose
Moderator
Moderator
What version of JSS? If you're not running the latest version then you may
On 11/25/10 6:26 PM, "Baykara, Cem" <Cem.Baykara at BSKYB.COM> wrote:
want to check the release notes from the newer versions.
Also, are you importing a manifest or a .plist file? They're similar but
not the same.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
Cem
Valued Contributor
JSS v7.31. I have tried MS Office manifest com.microsoft.plist and plist file com.apple.loginitems ...but both files have been successfully imported by JamfSupport on their JSS??!! There's something to do with my server I believe...I have fixed permissions rebooted and repaired MYSQL db too.
Sent from my iPad
T_Riding
New Contributor
Hi Cem,
We are also experiencing the "The selected file was not valid" error no matter what we do. Did you resolve this at all?
Cheers,
Toby
Cem
Valued Contributor
@Toby
It was something to do with firewall. But since I had this issue I have moved the server to different location with less restrictions and all good now.
T_Riding
New Contributor
Thanks a million, I'll try that.
T
franton
Valued Contributor III
We're still having issues with this, firewall up and down. It's been present across all the JSS vm's we've ever built from 8.62 up to 8.71. The JAMF software log file shows the entire .plist contents but some sort of XML parsing error. Any thoughts?
CypherCookie
Contributor
This issue is actually to do with the server needing to speak to the Apple servers to compare the plist file before it is allowed to upload to the JSS server. If the firewall restrictions were taken down a notch this could resolve the issue. Obviously you need to decided if you can do this before hand or not as some company's do not allow this subsequently this means that you are not able to get the upload working at all.
