Problem with installation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 09-08-2015 05:37 AM
During the installation , the installer fails .
The current OS version is 10.10.3
The console logs are this .
I have tried many different OS versions but the problem still exists . I cannot fully install .
I tried also to execute the .pkg via sudo command but neither this worked .
There is also a similar post but without any solution .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-08-2015 06:16 AM
@dgkanavias is this a QuickAdd package that you are trying to install or something else? What version of the JSS are you running?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-09-2015 12:36 AM
@mpermann Yes it is a quick add package & the version of JSS is 9.72 .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 09-09-2015 05:48 AM
@dgkanavias is the QuickAdd package one that was built using the Recon application or did you download it from the /enroll URL? If you are using a QuickAdd package from the /enroll URL I would suggest you build a package using the Recon application and try that instead.
Do these systems already have a version of Casper installed or are they systems that have never had the jamf binary installed? If they've already had the jamf binary installed you may need to do a
sudo jamf removeFramework
on the system before installing from the QuickAdd package. I've occasionally run into problems installing a QuickAdd package when the jamf binary already exists on the computer.
Edit: Also, you might want to take a look at the /var/log/install.log file to see if there is anything helpful in there.
