- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 08-30-2022 10:40 PM
I'm trying to write a generic script to set default app for a document type e.g. PDF using https://github.com/Lord-Kamina/SwiftDefaultApps/releases
This works from a policy where $4 is set to: /Applications/Nitro\ PDF\ Pro.app
and $5 is set to com.adobe.pdf - but in the script I explicitly ignore $4 and set application_name
# SetDefaultApplication.bash
#application_name="$4"
application_name=/Applications/Nitro\ PDF\ Pro.app
echo $application_name
# e.g. /Applications/Nitro\ PDF\ Pro.app
uti_name="$5"
# e.g. com.adobe.pdf
currentUser=$(stat -f%Su /dev/console)
# setHandler
sudo -u $currentUser /usr/local/libexec/swda setHandler --application "$application_name" --UTI $uti_name
and in the policy I see the output as:
Script result: /Applications/Nitro PDF Pro.app
SwiftDefaultApps SUCCESS: Default handler has succesfully changed to com.gonitro.NitroPDFPro
But, if I try and use $4
#application_name=/Applications/Nitro\ PDF\ Pro.app
uti_name="$5"
# setHandler
I get an error from the policy
Script result: /Applications/Nitro\ PDF\ Pro.app
SwiftDefaultApps ERROR -10814: No application found for /Applications/Nitro\ PDF\ Pro.app
and yet on that machine, I can run the script as root
dep54592:lab root# ./SetDefaultApplication.bash 1 2 3 /Applications/Nitro\ PDF\ Pro.app com.adobe.pdf
Just wondering if anyone can see where I'm going wrong?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-31-2022 05:38 AM
@dlondon Are you using /Applications/Nitro\ PDF\ Pro.app or just /Applications/Nitro PDF Pro.app as Parameter 4 when calling your script from Jamf Pro? If the former, what happens when you try the latter?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-31-2022 06:02 AM
When using application_name="$4" in the script, it implies that the variable would be passed as double quoted, in which case you don't want to use a string for $4 using the backslashes. "/Applications/Nitro\ PDF\ Pro.app" is not a valid path and the error is indicating as such. So, basically the same thing that @sdagley is implying in their post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 08-31-2022 06:40 PM
So here's a cleaner copy of the final script with credits and explanations
# David London
# 2022-09-01
# With help from sdagley (Steve Dagley) and mm2270 (Mike Morales)
# in https://community.jamf.com/t5/jamf-pro/problems-running-a-script-quot-as-user-quot-in-policy-and-using/m-p/272752#M248439
# Initial direction from the end of this post on using swda https://community.jamf.com/t5/jamf-pro/setting-default-open-with-app/m-p/11473
# This is a generic script that uses the command line component of SwiftDefaultApps
# available at https://github.com/Lord-Kamina/SwiftDefaultApps/releases
# This script will set the default app for a file type for the currently logged in user
# The script is intended to be used in a policy and a copy of the command line component of SwiftDefaultApps has been placed in a known location
# In this case the known location of swda is /usr/local/libexec/ but it could be anywhere e.g. /tmp
# For me, I just package up swda in /usr/local/libexec and deploy that first before the script in the policy
# grab $4 e.g. /Applications/Nitro PDF Pro.app
# grab $5 e.g. com.adobe.pdf
uti_name="$5"
# get the current user
# setHandler
and in Jamf Pro the parameter tab looks like this
T
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
# David London
# 2022-09-01
uti_name="$5"
# setHandler
T
