Problems when aplying policies - Login Users
  • September 11, 2018
  • 1 view
Hi Everyone,
When we apply the policies in the MACs, We are having some issue because users are not able to change the session to another, when somebody has logged in in the machine and another person need to log in, there is no option whice let change the session, He needs to restart the equipment, so it is no a good option.
We tried to changed in the users and group windows but the option is in gray as the attached. I need to know where to change it in JAMF Console.
1 reply
@soportetpco Do you have Configuration Profiles enabled in your environment?
If so, find the profile that is being pushed to your machines and make an adjustment on the Login Payload.
Make sure "Enable Fast User Switching" is selected. Distribute to All and restart your machines to see if it updates.
