Posted on
08-18-2018
12:31 PM
- last edited
3 weeks ago
by
kh-richa_mig
Hi all,
I am currently testing Jamf Pro for my company using a trial software.
Our test Mac is DEP enrolled with profiles, policies etc. Including FileVault2 which engaged and worked fine, I decided to test the remote wipe command which worked as expected.
So I then Internet recovered the OS and started Setupassistance which enrolled it back into Jamf Pro but FileVault2 would not turn on even after several logouts and reboots.
Inside Jamf I can see several errors for all profile configs which had the messages Profile with identifier 'MacOS Energy Saver V1' not found with a command of Remove MDM profile.
I can eventually get the policies and profile configs to work if I manually run
- sudo jamf flushprofilehistory
- sudo jamf recon
- sudo jamf policy
What is the actual process after remotely wiping a computer? Am I meant to delete the computer account from Jamf Pro before I re-enrol it again?
