Remove Fonts
dj562006
New Contributor II
We have a number of fonts installed on the Macs that we used a configuration profile to get them on the laptops. What is the proper way of getting those fonts off of the laptops now using Jamf?
5 REPLIES 5
sdagley
Esteemed Contributor II
@dj562006 Have you tried removing the Macs from the scope of the Configuration Profile that deployed the fonts? If that doesn't remove the fonts you'll need to run n rm command to delete the font file from /Library/Fonts, or the Library/Fonts folder in the user's directory (it will depend on if the profile was scoped to the Computer or User level)
dj562006
New Contributor II
I havent, I wasnt sure if it was that simple as unscoping them and it would uninstall the fonts.
sdagley
I haven't tried deploying fonts via a Configuration Profile, but when installing a certificate that way removing the profile removes the certificate.
JeffreyGarcia
New Contributor
Have you found your answer?
Yeah, when we removed the devices scoped to the configuration profile it removed the fonts.
