Removing JAMF and screen saver
joerod
New Contributor
Just curious if there is a way to remove the screen saver greyed out setting once JAMF is removed from a client.
3 REPLIES 3
donmontalvo
Esteemed Contributor III
MCX is set by Casper agent, but doesn't get removed when agent is removed.
https://donmontalvo.com
joerod
New Contributor
Thanks donmontalvo after removing the casper client this worked for me
rm -Rf "/Library/Managed Preferences"
jarednichols
Honored Contributor
@joerod
Depending, you may also need a
dscl . -delete /Computers/localhost
