removing Jamf Pro Built-in CA
raphhyyy
New Contributor III
I'm in the process of migrating users from a company we just purchased to our JAMF instance... i can remove the MDM profiles using using the command: "sudo jamf removeMdmProfile && sudo jamf removeFramework" through a policy, but the Jamf Pro Built-in CA is still there after that...
I want to be able to remove the Cert remotely...
Anyone have suggestions?
0 REPLIES 0
