Posted on 03-23-2016 02:46 PM
Here's a simple EA that would be good to have:
#If profiles are on the computer it spits out:
#profiles are installed on this system
#otherwise:
#profiles are not installed on this system
profile_status="$(/usr/bin/profiles -H)"
echo "<result>$profile_status</result>"
You can then create a smart group that reports against this EA and a policy that uses the "Files and Process" payload to execute the command:/usr/local/bin/jamf mdm; /usr/local/bin/jamf recon
This is good to have just in general anyways. But I'm sharing this specifically because I do not believe the MDM will just re-enable itself when Apple resolves its current problem. So it'll take a little effort on your end to determine which computers don't have profiles on them.
Also vote this up: https://jamfnation.jamfsoftware.com/featureRequest.html?id=4619
Posted on 03-23-2016 02:50 PM
You might also be able make use of this EA as well which counts profiles on the computer:
profiles="$(profiles -C | wc -l)"
profile_count="$(echo $profiles - 1 | bc)"
if [ "$profile_count" -gt 0 ]; then
echo "<result>$profile_count</result>"
if [ "$profile_count" -le 0 ]; then
echo "<result>0</result>"
And there may be other EAs out there people are using to spit back actual config profile names which allow for more granularity in reporting.
