Posted on β06-26-2015 03:31 PM
Some back story, I have a policy that caches an update, and another policy that installs the cached package at logout/restart.
I have another policy that has a simple script that popups and tells users that they need to restart to complete the install. (management is against forcing people to restart). I want this script to run every 3-4 hours so that they continue to get this popup until the update is installed. I see there is a custom event but can't seem to figure out how to setup a custom event.
Posted on β06-26-2015 04:09 PM
Hi, a custom event is a word that you call using a script. So if I create a policy with a custom event called "dave" I would use:
sudo jamf policy -event dave
in my script to trigger it on the clients.
The only way I can think to do what you need is to install a new launchdaemon on the clients that runs and uses the custom event you specify.
