- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
04-26-2018
11:21 AM
- last edited on
03-04-2025
07:44 AM
by
kh-richa_mig
We are deploying some software that prompts for local admin credentials when executed, which is problematic as most of our users have Standard accounts. I wrote up these couple of lines in bash:
#Runs $PROGRAM as localadmin admin account to avoid requiring admin rights
sudo -u localadmin open /Applications/Utilities/PROGRAM.app/Contents/MacOS/PROGRAM_BINARY
and made it a policy available in Self-Service. This works, in that the program does the needful even if the user has a Standard account, however, the Terminal app launches as well, and does not go away after the software is done doing what it needs to do.
Is there a way to use the "open" command in a way that doesn't open Terminal? Or another way to execute an application as local admin?
Thanks,
-Mike
Solved! Go to Solution.
- Labels:
Scripts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-26-2018 12:39 PM
Have you tried just opening it at the app bundle level instead of the executable? I think the reason for the Terminal launching is because you're calling the executable inside the MacOS folder. Try just opening the app, meaning
And you probably also don't need the sudo there since it will be running as root by default when run from a jamf policy.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-26-2018 12:11 PM
Have you tried entering the command in the "Files and Processes" -> Execute Command section instead of deploying a script?
We are doing this exact thing for a program called Provar that needs to run as admin once to enable git integration.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-26-2018 12:28 PM
Yep, I tried it now, and it still launches Terminal like before. The interesting thing I noticed too, is that if I close Terminal, it terminates the software app since it seems to "own" the process.
-Mike
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 04-26-2018 12:49 PM
@mm2270 Thanks, that worked!
