sanitize illegal filenames for OneDrive Synch
teodle
Contributor II
Hey all. I finally got a chance to refine this little Self Service app and it works great. User can now pick a folder to sanitize in preparation for moving to the OneDrive Synch folder. Still have a lot of non-compliant Mac users who need to get important stuff in the Cloud. The script we have now in production doesn't give the user a choice. It automatically runs on their existing OneDrive Folder, which is okay, but I would like users to be able to run it in advance before they even sign into OneDrive for the first time to avoid synch errors right off the bat. Before this gets into production, however I have two questions.
  1. How to best prevent a user from selecting any any folder outside their own home directory, where illegal character removal might break something.
  2. How to make it so this script also fixes illegals in the parent directory? It may not seem much to ask someone to fix ONE illegal filename manually after the script fixes the other 3,000, but I want to make it bulletproof.
Here's the script as it stands. It runs perfectly as a Self Service Item in our test instance of the latest version of JAMF pro.
##crowdsourced by teodle and jamfnation
USER="$(stat -f%Su /dev/console)"
#logged in user chooses a folder
FOLDER=$(sudo -u $USER -H /usr/bin/osascript << EOD
activate
set FolderName to POSIX path of (choose folder with prompt "Please choose a folder to sanitize")
end tell
EOD)
echo "$FOLDER"
cd "$FOLDER"
#now that a folder has been chosen, we run  zmv command AS THE USER to  remove, by brute force, all spaces, slashes and other illegals and replace them with underscore
sudo -u $USER -H /bin/zsh -c "autoload zmv && zmv  '(**/)(*)' '$1${2//[^A-Za-z0-9.]/_}'"
sudo -u $USER -H /bin/zsh -c "autoload zmv && zmv '(/) ()' '$1$2'"
osascript -e 'display notification "Your  Folder has been sanitized" with title "JAMF Management Notification"'
2 REPLIES 2
Grant_Campbell
New Contributor
Hi Teodle,
How did you go with this? I am also looking for a solution. Thanks
bootrec
New Contributor III
I like your script and would like to use it to prep for my organization's move to OneDrive folder backup. Seems we also need a function to shorten filenames that exceeds the OneDrive allowance. I have no idea how to code this.
