SCEP Issue with Ventura
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 07-04-2023 08:04 AM
Hello Nation, I'm having the issue where SCEP configuration works fine for Monterey but it doesn't for Ventura, the error only says Unable to obtain certificate from SCEP server at “ADDRESSXXX”. <MDM-SCEP:15002>
No sure what to do here and if anyone has make this work with Ventura?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-04-2023 07:56 PM - edited 07-04-2023 08:01 PM
@Valcovish I was going to ask if you'd opened a case with Jamf Support but I see from (https://developer.apple.com/forums/thread/720040) on Apple's developer forums you have. You might also try usingFeedback Assistant to report the problem to Apple if you haven't already.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-05-2023 03:42 AM - edited 07-05-2023 03:54 AM
I did tried feedback assistant without any luck, I don't think Apple is working on this problem either, no sure how we are going to fix this, Jamf Support doesn't know either.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 07-05-2023 07:04 AM
@Valcovish Are you using Active Directory Certificate Services as your PKI system? If so, have you considered setting up the Jamf AD CS Connector so that you can have certificates installed via Jamf Pro and bypass the SCEP request from the Mac? (An additional benefit is that you don't need to have a Mac connected you your org's network like you do when using SCEP for cert requests).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-05-2023 03:43 AM - edited 07-05-2023 03:53 AM
I wonder with almost everyone having this problem, why hasn't been address
